GS 1971-1991
H ιδέα είναι από το βρετανικό ιστότοπο του Τζούλιαν Μαρς, που αναπαράγει το παρακάτω άρθρο του βρετανικου CAR (1991)
Συγκρίνει GS με ZX... Σημείο προ σημείο!
THE MOST COMFORTABLE SMALL CAR in the world, people said. Others went further: the best small car of all (well, that or the Alfasud). Certainly the Citroën GS in its early years was the most aerodynamic the most technically advanced, the purest in design and the most distinctive. But that was all a terribly long time ago. Now, after an interregnum of six years since the last GSAs. Citroën is back with the ZX, a new car to sit in size and price between the AX and BX, embodying what is, for the company, new thinking.
The ZX, in direct contrast to the GS, is calculatedly conventional. It’s a rather dull-looking five-door hatch powered by a four-cylinder transverse in-line water-cooled engine, its front wheels driven via an end-on gearbox, suspended on steel-sprung MacPherson struts, and its rear axle on trailing arms. Brakes are servo-assisted, using discs and drums on this basic 1360cc Reflex model. So what's new? Chiefly, a rear subframe mounted on bushes that deform in a shrewdly designed way during high sideways load, causing the rear wheels to turn slightly in the same direction as the front pair to improve cornering stability. It’s worth boasting about, and it works, but it's not unique. Also, some ZX models - but not this one - have a sliding and reclining rear seat, novel for a European car.
The GS has a four-door fastback body of remarkable aerodynamic efficiency, and a longitudinally mounted air/oil-cooled flat-four ahead of the front wheels. Front suspension is by double wishbones, rear by trailing arms, with interconnected self-levelling hydropneumatic springing/damping units at each corner. The high-pressure hydraulics also power the all-disc brakes, inboard at the front. There are more surprises: the steering axis passes exactly through the tyres’ contact patches so that the car continues in a straight line after a front tyre blow-out, there is a remarkable degree of anti-dive provided by the suspension geometry, and the rear brakes are pressurised by the rear suspension fluid so that their action is proportional to the car's load.
The GS tested here isn't quite like they were two decades ago. The GS first came with engines of 1015cc and 1222cc, designed with an eye to French taxation rather than performance. They were astonishingly high-revving, short-legged cars. This GS is the later X3 model introduced in 1978, its engine expanded to 1299cc in an attempt to help the 65bhp engine's torque and economy. It's still short-geared:15.4mph per 1000mph in top (fourth) means a 5500rpm motorway cruise is possible but deafening. But, apart from the bigger engine, the revised rear lamps and the ghastly seat trim, the X3 is as the GS was at the outset.
This car is owned half-and-half by me and deputy editor Richard Bremner, and we didn't set out looking for an X3 — we just wanted to buy a well-preserved GS of almost any description before they all rotted away.
Start up, and you know you're in something unconventional. it's not just the absence of water temperature gauge that points to the cooling method: there being no sound-absorbing liquid jacket, this is one loud engine. But it's a nice sound, remarkably like a pair of 2CVs or, if you prefer (and l do), two-thirds of a 911. Horizontally opposed engines, all of them, have a lovely soft-edged sound that rises in pitch and volume higher up the rev range while avoiding any harshness. They sound as though they'll never break.
Performance of G5 (top) and ZX is similar, new car’s greater torque offset by longer gearing.
ZX cleaves air quietly. Tyre noise. too, is well suppressed. GS falls down on refinement: it suffers noise from wind, tyres and engine. GS has a longitudinal 1299cc air-cooled flat four, ZX 1360cc transverse water-cooled in-line four
The ZX's engine, though a deal quieter in the middle ranges, isn't so nice to use as it turns rough when you push it, so you adopt a different technique when trying to get along briskly, using higher gears (you've five to choose from) and lower crank speeds. Performance of the two cars is very similar, the ZX's greater torque of 85lb ft against 72lb ft being offset by slightly longer gearing, while both cars weigh 19.5cwt.
Its uncouth engine apart, the ZX is clearly ahead of the 1991 class standard for refinement. It cleaves the air quietly, even though its drag coefficient, at 0.32, certainly doesn't reflect two decades’ progress from the GS's 0.34. Tyre noise is very well suppressed. There's no steering kickback or transmission shunt, and the gearshift has a light, clean-slicing action. It's an easy car to drive.
It's leagues ahead of the GS in refinement. The old car falls down badly here - by far its biggest drawback on the road. Beyond 70mph, the wind whips up a cyclone roar, accompanied by bad tyre noise and a shriek from the gears, yet still the engine's voice is strident enough to be heard above the cacophony. The gearchange is light and quick, but hasn't had the rough edge taken out of its action, and there's enough backlash in the driveline to demand great circumspection from the driver coming on and off the throttle.
Two decades have seen ergonomics move forward, of course. The GS dash is a right mess, and badly made with it. But the car's driving position is fine, and slim pillars impart airiness and visibility. The ZX counters with easily found, illuminated switchgear and proper modern heating and ventilation, where the GS has a weak-willed set-up directed by a scattered set of levers that sprout from roughly carved gashes in the frangible plastic facia.
Citroën badly wants the ZX to appear well made, and it does. Although the company's claim that it's the best in its class represents a combination of innocent naivety and cynical marketing hype (the seat trim and dash are of cheapo materials), the fact is the facia components all fit well, the heater dials turn smoothly, the glass is neatly semi-flush and the metal panels are thick and well fitting. More important, the fact that the body doesn't boom and crash over bumps is a great step forward for Citroën.
In the GS, you hear bumps, and feel them through the steering wheel. There's also some harshness over small, sharp bumps such as Catseyes. But real lumps, undulations, pot-holes, cobbles and broken surfaces are simply swallowed. No car today— up to limousine size - is so soft, and yet the GS seldom floats. To the owner of a backside accustomed to the jarring rides of modern small cars, it's amazing. On top of which, the car is unaffected by load.
By modern standards, the ZX rides well. It is resilient, moving up and down but taking the edge off things well. There’s none of the lurching and thumping a German car would serve up on lumpy French roads. Its big fault is an uncomfortable lateral rocking, brought about because the car, though softly sprung, is quite stiff in roll. Anti-roll bars are simply lateral springs, and undamped ones at that, so when one side of the ZX is disturbed the whole thing rocks. The GS, like the ZX, has anti-roll bars at each end, hut they are far less influential.
Ride quality, though, is but one element in the sum of comfort. Both cars have soft, generous seats, good driving positions and adequate cabin room. The GS has better rear-seat headroom, the ZX the better legroom, though for back-seat roominess, it's shamed by the Tipo.
In packaging, the two Citroëns are remarkably similar. The ZX is 160in overall, the GS two inches longer, the wheelbases are the same, the heights similar, yet the GS has the bigger boot by 45 percent when the ZX’s rear seat is up.
No progress there in 20 years. But surely all this softness in the GS must make it handle like an inebriate camel? Not a bit of it. Sure, it rolls onto its door handles, but it clings on amazingly well with its round-shouldered tyres, understeering insistently at the limit.
There's excellent directional stability yet neat turn-in: the steering is very direct and accurate, though you pay a price in having to put up with kickback and a marked weighting-up in bends. The GS‘s big 15-inch wheels help the ride and give a reasonably big contact patch from 145-section tyres.
The ZX rolls less, as it must in order properly to exploit modern lower-profile 165/70 13 tyres. Drive the ZX’s contemporaries and you'd call its steering light, quick and accurate, but after the GS‘s it feels a tad rubbery, which must be the pay-off for losing the kickback. Still, the ZX turns into bends eagerly enough, and then brings its self-steering axle into play by tracking around the arc with remarkable tenacity and even-handedness — tucking in only gently even when you throttle right back – and gripping very strongly. Its two-stage cornering action feels odd at first, but you soon learn to like it — a real Citroën characteristic, you might say.
The ZX doesn't have real Citroën brakes; the GS does, and is the better for it. On almost no pedal travel, the GS discs have sharply honed initial bite, great power and perfect progression, aided by the car's remarkable resistance to front-end dive. Their high-pressure hydraulics can also be cheaply adapted to ABS, and have been on the BX and XM. The ZX’s stoppers work well enough but feel spongy beside conventional opposition's and especially so beside the GS's.
So just what does Citroën have to show for 20 years‘ developments? To look at, drive or sit in the two cars here, you'd be hard put to find much beyond the refinement angle. But look at the costs.
Soft suspension has GS (top left) rolling around bends, but it holds road well. ZX turns in eagerly, corners evenhandedly. Rear seats are soft and
generous in both cars, their cloth trim showing Citroën hasn't lost its taste for garish colour. GS has switches scattered over Its messy clash. ZX's facia is neater —has better ventilation (above)
In its youth, GS was most distinctlve car around, and the most aerodynamic. Its 0.34 Cd compares well wlth ZX's 0.32. New car's design is calculatedly conventional. Both cars have good driving positions and adequate cabin room. Not only ls GS’s dash a mess, it’s also badly made. ZX’s facia (above) is blander but better to use
The GS's 27 to 32mpg isn't too clever when you’d be doing nearer 40 in the ZX, and an early GS's 3000-mile service interval would horrify a 1991 owner. A GS would need 30-odd hours‘ servicing in its first 60,000 miles whereas this ZX gets by on 5.5 hours plus oil-changes. You'd swear maintenance wasn't given a second thought when they designed the GS - the distributor is so badly sited you need to remove it to check the points – yet the BX proves that with modern design, electronic ignition and today's lubricants, the care of a hydropneumatic car needn't be a problem.
The GS is reliable if cared for, and mechanically durable, but in damp, salty Britain its body disappears like April snow. TheZX is carefully designed to eliminate rust—traps, and 75 percent of its steel is galvanised or electro-plated. It should last well and when it's done for, its constituent parts will be labelled for recycling.
The ZX is strong, having a very rigid floor and three hoops over the cabin for stiffness and rollover protection. It is claimed to be safe in 35mph frontal impacts where the law demands 30mph, and to deal with offset crashes, too, for which there is no legislation. The GS isn't bad in its crash resistance. but the ZX is better. Yet in primary safety, the ability to avoid the crunch, the GS lags little.
‘I can’t imagine,’ said someone from Citroën at the ZX‘s launch, ‘that anyone who drives our car will have anything to complain about.’ Well I, for one, will grumble. However good the ZX may be (and it is very good), it's not a car to hold your interest. As far as Citroën is concerned, it's hardly a car at all. It's a product, an appliance, carefully tailored to existing consumer demand in market segment Mi. The buyers know what they like, and Citroën has inferred that they like only what they know. So the ZX is just what they know, a little better all round, but no different. It is, in short, a marginally improved competitor to Bland X.
Citroën makes cars to make money, and we can't blame it. There's only sense in building something different if it can be economically made and abundantly sold. The danger the ZX faces is its perilously short potential lifespan: before long there’ll be a new Golf, a new Astra, a new 309, several new Japanese, and any or all of these could well better the ZX, leaving Citroën floundering for a replacement.
The GS, by being different, has qualities that haven't been bettered in 20 years, and perhaps never will be. Its faults are evident and manifold: it is unrefined to drive and, though reliable, is extravagant in its demands for fuel, care and attention. But all of these could surely be cured by modern design and engineering, without abandoning hydropneumatic systems, adventurous styling and sophisticated (though not necessarily complex — the GS isn't complex) engineering. The very thought of it all makes the ZX seem like a wasted opportunity.
Paul Horrell
This was one of four articles in this issue comparing then current models with their predecessors from twenty years previously. The other comparisons were Jaguar XJs with E-Type, Audi 100 with NSU Ro80 and Alfa 33 4WD with Alfasud.
These are the conclusions:
Cost
WE'RE PAYING A LOT MORE FOR OUR CARS now than we did 20 years ago, once you take inflation into account.
Example: in 1971, an Escort 13O0XL cost £1004 including tax, whereas today's Escort 1.4LX is £10,125. In the meantime, the Retail Price Index has risen so that £1.00 in 1971 would buy what £6.74 buys now. Thus you might expect today's Escort to cost just £6767.
Similar figures apply pretty well right across the spectrum. In '71, a Jaguar XJ6 4.2 auto was £2969; multiply that by 6.74 and you'd expect to pay £20,011. Instead, Jaguar asks £29,880 for an XJ6 4.0 auto. The table gives more examples of then-and-now prices; in each case, there's a gap between what inflation would lead you to expect to pay, and the actual price now ~ and sometimes it's a chasm: an Austin 1800 (£1246) points to a price for a base Rover 820i of £8398 not the actual £17,181.
Don't imagine the recent VAT increase signals an overall rise in tax. In 1971, you paid 30.7 percent purchase tax; now, it's roughly 8.0 percent special car tax (actually 10 percent of wholesale price) with 17.5 percent on top, amounting to 26.9 percent in all.
Car makers would have you believe labour costs have gone through the roof, but in fact Ford's line workers were paid 75.5p an hour in '71 ; now they average £5.89 - only a small real increase. And Ford in Britain turns out roughly twice as many cars per employee now as it did then.
Perhaps greater sophistication and better equipment could justify higher prices. Our pair of Escorts again: the difference between the expected price extrapolated from '71 and the actual '91 price is £3358. What do you get for it? In '71 you suffered a pushrod motor and cart-sprung live rear axle, and you paid extra for servo-assisted front disc brakes, cloth seat trim, a heated rear window, radial tyres and AM-only radio. Today's 1.4LX - which has all-independent suspension, a five-speed gearbox and an ohc engine – includes as standard an array of goodies the '71 car had to do without: halogen headlamps, sunroof, electric front windows, rear foglamps, intermittent wipe, rear wiper, door mirrors, locking fuel filler, side window demisting, reclining seats, clock, tripmeter, stereo radio-cassette player, hazard flashers, boot light and burglar alarm. An impressive list, but is it worth £3358?
Styling, Engineering
OVER THE PAST TWO DECADES, THE choice available to buyers has been lamentably narrowed. We've already examined (CAR, July 1990) the way in which cars are looking more and more alike – a trend that's not convincingly justified by the demands of their aerodynamics or safety.
The real reason could be called prudence or cowardice: manufacturers simply refuse to build adventurous designs in case they turn out heroic failures, opting instead for the safe course of building near-clones of what's already selling well.
Under the sheetmetal, the convergence between manufacturers is even clearer. Certainly, the transverse engine is good for interior space, and front-drive bestows both roominess and predictable handling, the coil-sprung MacPherson strut is cheap to make and compact. But is this really such a magic formula? In the '70s, we were offered particular engineering solutions to particular problems; nowadays every car's much the same. In 1971, Fiat sold the rear-engined 850, the front-engined, front-drive 127 and 128, the rear-engined, rear-drive 124 and 132, and the V6 130. The X1/9 and 126 followed in '72. Now, there's little fundamental variation in engineering from the upcoming
Cinquecento microcar through the Panda, Uno, Tipo and Croma -taking in the Lancias Y1O, Dedra and Thema on the way. In '71, Lancia offered narrow-angle V engines, flat-fours, transverse leaf suspension, and coachbuilt coupés.
There are some modern exceptions to this oppressive conformity. The Metro’s fluidsuspension; the Renault Espace's space utilisation and unique body construction; the Lotus Elan's bold styling and clever front-drive engineering; the Citroen XM's step-ahead suspension; the Honda NSX’s radical aluminium construction; the Audi Quattro’s four-wheel drive — none of these features has hampered sales success.
Detail engineering has moved on, of course. We now have widespread fuel injection, electronic ignition, ABS, turbos, better bumpers, flush glazing, rear-wheel steering (whether active as with Honda, Mazda and Nissan, or passive as with Porsche, VW and Citroën), better auto gearboxes and smoother diesels. But revolutions have been too few, we think.
Performance, Economy
THE TABLE GIVES EXAMPLES: IN GENERAL, comparable cars are faster now, and a little more economical. Performance is no longer the preserve of the few, either; an Astra GTE 16-valve of '91 performs near-identically to 1971's 4.2-litre E-type.
Yet no-one could say performance and economy have leapt ahead. The motivation to improve economy hasn't really been there, in that a 1971 gallon of four-star cost 35p including taxes, which would be an inflation-corrected £2.36. So fuel is cheaper now than it was, and the trend has been for us to choose to drive faster in quicker, heavier cars.
Engine efficiency has barely risen. For mass-market 1.0 to 1.6-litre engines, power output per litre has risen by just 10 percent or so in most cases. Expect no improvement over the next few years, either: catalytic converters will see to that.
Most consistent improvement has been in top speed, and in design for relaxed and economical motorway cruising. This has a lot to do with aerodynamics and the fall in from, say, 04.5-0.50 then to 0.30-0.35 now. But aerodynamic drag matters only from 50mph-odd upwards, and doesn’t affect acceleration, or fuel used during acceleration.
Acceleration has made less progress, because of the seemingly unstoppable trend for cars to put on weight. Again, the table shows the figures.
Sure, the extra equipment we expect these days adds to a car's heft, but if car makers and their computerised design aids are as clever as they claim, they should be able to save weight elsewhere, chiefly in the metal body of the car. With a few exceptions – the Citroën AX and Honda NSX among them - that hasn’t happened.
Handling, Roadholding
IN 1971, YOU COULD BUY A FEW FRONT-wheel-drive cars that handled predictably and safely. Now almost every car-maker builds them, for the gap between worst and best is much narrower. And the rear-drive cars - many of which had rude swing axles or cart-sprung live axles — now tend to be better engineered and a lot more orderly on the road, too. But the real enthusiasts‘ cars are perhaps little better balanced or responsive than they were. The Lotus/Caterham Seven can still stand proud. In roadholding, though improvement has been universal.
No question, cars grip better now than they did, and by a wide margin. Who deserves the credit? Not really the car makers. Step forward Pirelli, Michelin et al.
Since the first Pirelli P7-shod supercars emerged more than a decade ago, the wide low-profile tyre has become accepted for most cars bar the very basic, and their chassis characteristics have had to be tuned to suit. Everything that doesn't use a beam axle or a De Dion tube has to corner flatter to keep these wide tyres perpendicular to the road. Hence the firm springing and stiff anti-roll bars we've become used to.
There are other unfortunate side-effects of ultra-low profile tyres. Once they do relinquish their hold of the tarmac, they go suddenly and you'll be travelling fast. Extrovert sideways driving is seldom on the menu these days. Ultra-low-profile tyres tend to follow the camber of a road, and to induce tramlining under brakes. Most noticeable of all, because these tyres are so resistant to changing direction at parking speed, power steering has become far more frequently specified, and even in 1991, not every maker can build a steering servo that achieves the happiest combination of accuracy and feedback.
High-power front-drive cars demand further compromises in suspension design if torque steer is to be controlled. At least the Lotus Elan offers hope here.
Steering precision hasn‘t made much headway. To insulate their cars from harshness and road noise, today’s designers use the cheapest solution, rubber bushings throughout the steering system. The result is often a loss of precision - felt as rubberiness or a softness of response in the straight-ahead - compared with the best of two decades ago. If you doubt this, drive a Mini.
Comfort, Accommodation
DRIVE ONE OF THE MODERN CARS IN OUR back-to-back comparisons on the preceding pages is significantly more comfortable or space-efficient than its predecessor and they aren't freak examples. Look at the Mini, Maxi and Austin 1800 (emphatically roomier than a Rover 800, yet two feet shorter). And all the while, people are on average, getting taller.
Ride comfort is, at least in a conventional steel-sprung car, one half of a compromise. The ride/handling compromise, road testers used to call it. Now, every maker has arrived at much the same compromise of stiff springs and thick anti-roll bars, brought about by the developments in roadholding we’ve just discussed, and the phrase is seldom seen. True, today’s independently sprung Escort rides better than yesterday's cart-sprung example, but we can’t buy Renault 16s or Austin 1100s or NSU Ro80s any more — we simply aren’t offered the choice of a soft-riding car.
Where are the new solutions’? Active-ride prototypes have been kicking around for a decade, but there's nothing in the showroom. There’s a semi-active Infiniti, but you can't buy it in Britain. The Citroen XM's chassis is ahead of the game and few other makers seem even to be trying to catch up.
In refinement, there has been some progress. Engines are smoother, gearboxes less reluctant (except for Fords, as a '91 Fiesta or Escort‘s change is still a lot less slick than a rwd '71 Escort’s), clutches smoother, wind noise better suppressed. We also get more supportive seats these days, and improved heating and ventilation.
Buyers love gadgets, and they're getting more and more. All add to an impression of luxury and many are undoubtedly of genuine use. But seat, window and sunroof motors add stones of weight to a car. So do the subframes and extra wads of sound insulation that makers are using to defeat the noise demon, when they can't defeat it by building fundamentally quieter mechanical organs. It's weight that saps performance, dulls handling and increases thirst and emissions. It's easy and cheap to add weight, clever to lose it. Car makers aren't being clever enough.
Reliability, Servicing, Longevity
AT LAST, SOME REAL lMPROVEMENT. If anyone says the Japanese didn't innovate in their early years of car making, point them to the reliability of almost every Honda, Nissan, Toyota or Mazda that ever took to the road. Consistently made, reliable cars are the norm now, due to improved production engineering and greater automation.
In the early '70s, cars on this island rusted out long before they wore out. Three or four years was the norm before the first rust appeared. Now, we have careful design to eliminate rust traps: PVC wheel-arch liners, plastic protection, hi-tech undersealing, zinc coating, better painting and so on, and progress has been more than satisfactory.
Servicing costs have, in real terms, tumbled. Cortina 1600s had 6000-mile intervals, Sierra 1.6s have the same. In '71, a Cortina service averaged £29, which is an inflation-corrected £195, yet for the Sierra today it's just £42. For a 4.2 E-type, you had to spend between £55 and £90 at the garage every 3000 miles; for a V12 XJS it's just £77-£150 every 7500 miles.
Safety, The Environment
IT'S THE REIGN OF THE LEGISLATOR. CAR companies are given to pleading that they've had to put so much effort into meeting safety and emissions laws that they've been distracted from moving ahead on other fronts.
Well, they have made real progress here. Active safety first: extra grip, more predictable cornering and ABS brakes play major roles. In crashworthiness, the gains are harder to measure. European impact laws are still a long way behind those in the States, but are tighter than they were in the early '7Os.
On emissions, the first laws in Britain came into force in 1976, and they have grown progressively tougher. But not until 1993 does Britain enforce standards the Americans had back in 1983.
Modern three-way cats provide clean air, but remember, they do nothing for fuel economy, something that has in any case not moved forward much since '71. And every molecule of petroleum burned produces carbon dioxide, non-toxic, but, because of the greenhouse effect, likely to be the biggest long-term worry of all.
Car makers are taking laudable initiatives towards recycling, though it's too soon to say what the results will be, and some eminently recyclable materials haven't yet found widespread use — aluminium for instance.
But we haven't seen the big advances, the ones we hoped for during the first fuel crisis 18 years ago, in energy reduction. Cars still cost vast amounts of energy to build and run, and it's still oil they use. Alternative fuels and different types of engines are coming, they tell us, but we're getting impatient.
Conclusion
CAR MAKERS HAVE GOT LAZY IN THE PAST 20 years — and that's why we haven't seen the progress we should have done. Those great innovators of the past — Citroën, Audi, Alfa, Jaguar, Lancia, Renault, Fiat, Leyland — have played safe, unwilling or unable to be different. And because the clever companies have gone conservative, the mainstream makers have hardly been keen to rock the boat, either.
The greater conservatism can be attributed to the higher development costs for new models, so that manufacturers are less willing than before to try to do something different - for fear of an expensive failure. It can also be blamed on the tendency for big, conservative firms to swallow up, and expunge the quirks from, the smaller makers (Fiat‘s buying Lancia; Peugeot's buying Citroën). It's cheaper for a major maker to standardise, as much as possible, every car in its range. The perfidious influence of marketing - which relies on non-experts, used to today's standards, to unlock the secrets of tomorrow - is also culpable.
But we believe there is real hope, for the next 20 years. Social and political pressures will force car makers to innovate; if they don't do things differently 20 years from now, they won't be in business. Such change is good news for the average motorist, and good news for the enthusiast, intrigued by innovative cars. Great cars of the past have often been born from crises (the Mini, don't forget, was a direct upshot of the Suez crisis, and the threat of massively more expensive oil). The trouble with the '80s, one of the least innovative decades ever in motoring, was that we all had it too easy.
Λογω χρονου δε το διαβασα ολο. Mε σιγουρια μπορω να πω ομως ως κατοχος zx 1.4 και περιστασιακος οδηγος των GS του Μιλτου οτι η GS εχει καλυτερα φρενα και μπροστινο συστημα και ειναι και πιο ανετη βεβαια απο την ηδη ανετη zx. Σε πολλα αλλα σημεια ειναι φανερη βεβαια η εξελιξη των 2 δεκαετιων. Εννοειται οτι σχεδιαστικα προτιμω τη GS.
πάντως στα 145 αρια ελαστικά της GS μπορεί να είχαν ύψος σε σχέδη με το μικρό πέλμα τους, αλλά δε νομίζω ας ότι το προφίλ τους η΄ταν πιο ψηλό από ότι στα 165/75 ας πούμε. Αν κάποιος έχει στοιχεία για το προφίλ των παλιότερων ελαστικών, τότε που δεν αναγραφόταν ως ποσοστό του πέλματος όπως στα καινούρια, ευχαρίστως...
Πάρα πολύ ενδιαφέρον.. Μόλις βρω λίγο χρόνο θα το διαβάσω όλο.
Ένα γρήγορο σχόλιο.. Το να συγκρίνουν ένα αυτοκίνητο που παρουσιάστηκε στις αρχές της δεκαετίας του 1970 με ένα σχετικά σύγχρονο και να βρίσκουν τόσα θετικά στην GS σε σχέση με την ΖΧ λέει πολλά.
:classic:
:classic:
Den divases to kimeno...
Me ton Julian Marsh echo sisitisi poles fores...ke den imastan tis idias gnomis arketes fores... Ine poli apolitos ke nomisi pos mono aftos kseri...den dechete ke kamia ali gnomi...
Χωρίς να θέλω να μειώσω (απεναντίας!) την πολύ σημαντική ιστοσελίδα "Citroenet" που έκανε ο συγκεκριμένος, εξ' αιτίας, όμως, κάτι τέτοιων "τύπων" σαν και τον συγκεκριμένο ξέκοψα από τη Βρεταννική λέσχη Citroen.... Άντεξα μόνο έναν χρόνο... Ελάμβανα το πάμφτωχο φωτογραφικά και θεματικά μηνιαίο περιοδικό τους (το οποίο είναι και βραβευμένο υποτίθεται) και αντί να διαβάζω για Citroen, διάβαζα τα εσώψυχα και την ψυχανάλυση του καθενός "Julian Marsh"... Άσε που συχνά εξυμνούσαν τα πλέον καγκουροποιημένα δημιουργήματά τους, τα οποία μόνο γελοιοποιούσαν τη Citroen παρά αναδείκνυαν την προσφορά της στην αυτοκίνηση. Και κυρίως, είναι πάρα πολύ άσχημο να είναι κάποιος ισχυρογνώμων, να νομίζει ότι τα ξέρει όλα και να μη δέχεται την γνώμη άλλων, πόσο μάλλον όταν αυτός ο "άλλος" είναι ένας άνθρωπος όπως εσύ που έχει τέτοια γνώση, εμπειρία και αγάπη για τις Citroen που πάρα πολύ σπάνια τη συναντάς...
Με αφορμή το συγκεκριμένο θέμα, μου έρχεται στο μυαλό και ένα άλλο: Αν θεωρήσουμε ότι δεν υπάρχει ούτε παγκοσμιοποίηση, ούτε άλλοι οικονομικοί/πολιτισμικοί περιορισμοί και η Citroen είχε το "πνεύμα" του παρελθόντος, πως θα φανταζόμασταν τα μοντέλα της Citroen σε κάθε κατηγορία σήμερα???
To άρθρο δεν είναι δικό του... Είναι από το βρετανικό CAR. απλα ανέφερα την πηγή...
Να πω και την προσωπική μου άποψη, από τη 12ετή εμπειρία μου ως οδηγός ΖΧ: Το μοντέλο αυτό της Citroen, όσο συμβατικό και εάν φαινόταν (τις ειδικές εκδόσεις του, ιδίως το Volcane 1.9 και πάνω από όλα, το 16v με τα 155 άλογα, τις βρίσκω και όμορφες!), νομίζω ότι ήταν η πιο αποτελεσματική και ικανή μη-υδροπνευματική Citroen που βγήκε ποτέ... Δεν υπάρχουν λόγια να περιγράψουν πως στεκόταν το αυτοκίνητο αυτό στον δρόμο. Και όσον αφορά τα φρένα που ανέφερε ο Χρήστος παραπάνω, έχει πέρα για πέρα δίκιο, είχαν ένα θέμα ιδίως στην αντοχή τους, αλλά νομίζω ότι αυτό αφορούσε περισσότερο τα 1.4. Από όσο γνωρίζω το 1.6 aura και φυσικά, οι ακόμα μεγαλύτερες εκδόσεις είχαν και απίστευτα φρένα...
Φαντάζεσται μία GS με ισχυρότερο κινητήρα, έστω τον 1.4 με τα 75, ή 1.6 με τα 90 άλογα του ΖΧ??? (ένα από τα μεγαλύτερα λάθη τις Citroen, ίσως, που δεν εξόπλισε με ακόμα λίγο πιο ισχυρούς κινητήρες τη GS, όπως έκανε την ίδια εποχή η Αlfa Romeo στην Alfasud.
ΠΑΙΔΙΑ ΧΡΟΝΙΑ ΠΟΛΛΑ ΣΕ ΟΛΟΥΣ ΚΑΛΕΣ ΓΙΟΡΤΕΣ ΚΑΙ ΥΠΕΡΟΧΕΣ ΒΟΛΤΕΣ ΜΕ ΤΙΣ ΚΟΥΚΛΕΣ ΜΑΣ....................
Επίσης Μίλτο, τις καλύτερες ευχές μου σε εσένα και στην οικογένειά σου! Πάντα υγεία και καλές βόλτες!
...me tis Birotor iche gini prospathia...omos bgike ksini...aftes ichane 107 PS!
προσωπικα δεν νομιζω οτι εχει νοημα αυτη η συγκριση...ειναι ολα διαφορετικα
τεχνολογια
αναρτηση
σχεδιο εξωτερικο
σχεδιασμος ταμπλο μεσα χειρολαβες κλπ κλπ
μοτερ
και το πιο βασικο το GS EINAI CITROEN ΤΟ ΖΧ ΟΧΙ το ΖΧ οσο καλο ειναι ειναι με πινελιες πεζω.....
